New firmware
jaapv
RFF Sponsoring Member.
4:31 PM
Firmware 1.107 is out on the Leica site... I'll wait till this evening with trying it though. ;)
Installed! I'm interested to see if it behaves any better than 1.102 which was giving me the occasional b&w striped screen or displayed the previous picture in auto review. It would also be nice if they have solved the "sudden death" syndrome where the whole camera would just go dead which has happened 4-5 times in the 8 months I've had it.
- Børre
I can't work this out ... when I go to the Leica AG site for the firmware update it only shows the PDF file for the instructions on installation ... no zip file!
Am I missing something ... I found and used the previous one ok! :confused:
At least my problems seem to be over with this version. Took 96 shots this afternoon. No b&w banded review images just after shooting and no previous image instead of last. The IR cast seems subdued although I didn't purposely test and appears only as fringe on greenery in strong backlit contrast.
- Børre
Hi ISO noise seems down quite a bit. Still not quite there for 2500, but the others are pretty good now - BIG improvement.
Downloaded and installed with no problems from the US/English site. Install went without a flaw. Will not know if there is an improvement till this weekend!
Done, installed, and first few pictures taken. Noise is MUCH smoother on white walls- chroma noise is down, at least. Pictures look nicer.
I also haven't seen the "big square" JPG compression artifacts, but I've not completed testing.
Wow! Just shot under three types of lighting, tungsten, florescent, and mixed. The WB looks dead on on the camera display. Noise is SMOOTH at 1250. Whoopee!
STeve
Thank you father Leica!
OK, about 50 images later I will have to say that the higher ISO images ARE smoother. I hope it is not my imagination. I wish I had taken some images just before the update to compare. I do not use higher ISOs often!
I'd love to put it on my own M8, but Leica has had my M8 since May 21st, and no sign of it coming back yet. Calls are not getting returned. I'm beginning to get extremely pissed off.
