New Summilux 35/1,4 Asph
Debusti Paolo
7:55 AM
Is the new Leica Summilux 35 asph lens really better than the previous version? Will it performs better on film or only on digital Ms?:rolleyes:Do you think that we can really see the differences on our film photos?;)what do you think about it?
thanks Guys:D
I'm looking forward to see how it performs. Steve Huff have review it using M9. Beautiful lens.. Hope it will produce much better bokeh with the film..
If you have a digital M I think the updated focusing mechanism gives better results. The earlier ASPH is fine if you use only film M bodies. I sold my 35/1.4 ASPH earlier this year as I wasn't using it, preferring a Summicron ASPH I bought last year. So far I haven't missed the Summilux.
I will use on m6 titan.I THINK THAT SHOULD BE THE BEST 35MM LENS FOR MY M6!!!!!!
I have one from Leica until Monday. I will be writing a review using the lens on an M film camera and Ektar 100 film. I'll compare it to the two other 35mm lenses I own: Summicron ASPH and Nokton Classic. I'll probably also do similar comparisons using my M9.
How about Tri-X or Neopan Acros-100 test also ... :angel:
I tested one earlier this year using film and digital. The lens is essentially identical to the previous version, but with better close-up performance and without visible focus shift. It's just as visible on film as with digital if you're looking as closely.
Marty
we are waiting for your opinion...;)
Marty
how big is it compared to the older one?
The lens I have has focus issues on my M9. Minimum focus is off and the rangefinder disengages.
I have no such problems with my other lenses. So, I'm holding off pending a response from Leica.
I have the 35mm Summilux pre-asph and will eventually add the 35mm Summicron ASPH f2 to the stable. I did own two 35mm ASPH Luxes (at diff times) and found a bit large for my shooting style.
A fast 35mm is the only lens yet to sit in my bag, but seriously.. What does the extra $4000.00 buy you over the Nokton f/1.2? I assume that the money buys a lens that is slightly sharper, especially peripherally wide open, better build, smoother operation and is lighter/smaller.
I've been playing around with the new version for a couple weeks now and some observations:
1. The new hood is way better than the old one and makes the lens more compact. In fact, when I had the previous version I usually left hood off since it made it so bulky. The new one, I leave on since it's hardly longer than without the hood.
2. Weight and size of the new lux with hood is close enough to the cron ASPH with hood that without a scale or ruler would be hard to tell just by picking it up. For a small/light walkaround package, I use a cron IV preasph since that's a noticeable difference to the lux.
3. Way less focus shift, now unnoticeable in regular pictures (ie not pics of rulers).
4. To me, the pictures have a very 3D look compared to the preasph.
Any pics pls?
The only thing it offers is size and possibly sharpness wide open towards the outer zones of the frame whereas the Nokton is mainly sharp around center.
Other than that, I think the Nokton is 4k better with smoother bokeh, if you care about that stuff.
Hi Dave,
It will be great to see those same image comparisons on film... I wonder about CV and Leica bokeh compared: I guess both lenses are sharp enough for most photographers...
Juan
