New Zeiss Ikon Rangefinder
ernesto
7:49 AM
Hello you all.
This is only speculative!
I have the impression that new technology will change the cameras as we knew in the past, and found that some other people seem to think the same way.
This is the description of a future camera.
First, it will be digital, of course, and full frame too.
Since digital tech will be faster, it will have an eyepiece with a micro digital screen that will show the image projected through the lens against the digital sensor in real time. There will have an optical viewfinder too, that could be seen through the same eyepiece, and if you want you could have both at the same time, by splitting the screen in two areas, or by adjusting transparency. This new viewfinder will have a prism, like in the obsolete previous rangefinders, that will make a composite of the optical image and the digital image. By adjusting liquid cristal filters that could block partiallly or totally the light coming through the optical viewfinder, so that you could customize your viewfinder accordingly the shooting circumstances.
Custom viewfinders will be available too. Some will be attached in the accesory shoe, and will have bigger screens, some other will be like sunglasses where the image through the lens will be wireless transmitted to the built in screen for your right eye while you could have extra information being projected to your left eye glass.
Remote operation will be possible through standard mobil phone systems, which will use internet.
So, it will not be a rangefinder, nor a reflex, since all previous concepts would be obsolete. In fact it will have the advantages of both previous systems, and that will be the reason for the SRLens systems death.
Therefore It will have the M mount, which is the new standard, and will be able to use all previous lens, adding full automatic focus, by moving the sensor plane as it did the Contax AX http://www.photographyreview.com/mfr/contax/35mm/PRD_83354_3105crx.aspx. It will have a focusing matrix, as the vintage Nikon D3, so that you could decide where to autofocus. Manual focus will be possible by switching the autofocus system off. Selective focusing or perspective control will be possible by tilting the sensor plane, manually or automatically, by focusing in 3 points, as this article explains. http://www.digit-life.com/articles2/m39var1/index.html
All kind of lens adapters will be marketed to use all previous and diferent brands, to be used in M mount, no matter if they were autofocus or not.
Ernesto
Heh!
While I can see the logic of DSLRs for long lenses, zooms and other stuff, it seems that for more general, more leisurely use, the ability to see what you've just shot on a digital camera (and check exposure, framing, focus etc.) makes reflex viewing in digital cameras less of an advantage than reflex viewing in film cameras.
In the less expensive DSLRs with the slower zooms, it's even more difficult to check focus and framing before the shot, and the reflex ability begins to look vestigial. Perhaps it always was. Many people buy SLRs because they want a camera they can control and get a good zoom for - and the fact they're able to look through the lens isn't material to them. They'd probably jump at the chance to have a smaller camera with smaller lenses - I'm thinking of all these tourists you see not taking that many photos and just laden with rucksacks and shopping bags.
ernesto said:
Hello you all.
By "full frame," do you mean the full 58mm x 58mm frame used on 120-rollfilm TLRs? Or the full 8mm x 10mm frame used on the Minox? Or the full 4" x 5" frame used by many press and view cameras? Or the full 45x107mm frame used on the Gaumont Stereo camera? Or the full 30x40" frame commonly found on lithographic process cameras? Or what?
All these, and many other, sets of dimensions could be equally argued as constituting "fullness"...
