Newton Rings on my Nokton 35 1.4 MC
Mr Scorpio
10:53 AM
Is this normal?
It's not normal, but shouldn't affect performance.
Some-times, separation looks like this, but I believe in this case it's just irregular coating thickness. Had it once on the rear element of a 40 Summicron, too, BTW.
Looks like the 'Gulf oil slick!'
I'd be asking for a replacement ... but maybe as Jon says it's normal?
Your lens got BP'ed.
Sorry I had to say that. I can't replicate that with my CV lens, but I've seem similar to that before under certain light condition although it was as pronouncing as your photo.
That effect is just from the coating. If it were separation, you'd be able to see tiny, ripply, crackly edges in the adhesive if you shone a light through it. The light is being reflected back within the thickness of the coating and scattered according to the different wavelengths of light which are being emitted by your bulb. Usually it's more apparent under lights with narrower band emissions like flourescent bulbs or some of the higher output lights with very narrow band emissions. Some would return more of one color and little or none of others.
And regarding the oil slick comments, yes, this is exactly the same reason that an oil slick looks this way or a bubble with a prismatic effect. The wave is interfered and reflected inside the film of oil or soap according to the thickness of the film matching or being an exact multiple of the wavelength of light.
Phil Forrest
If it is new, I'd ask the place from which you bought it about a replacement. if not everyone can duplicate the rings under your conditions, then it means there is something off about your sample. Replace it and enjoy this very fine lens in peace of mind ;)
My Zeiss Planar also does something similar.
That's interesting ... when I first got my ZF Planar I noticed that wacky pattern when looking into it and immediately took it off the camera and held it up to the light ... crystal clear!
Put it back on the camera and it looked fogged again. The mirror in an SLR really sets it off for some reason!
