next lens: Leica 35 Summilux v2 - Made in Canada
menos
11:24 AM
Shanghai
I picked up the lens, I bought on the internet from a German camera store.
It is a 35 Lux pre ASPH v2 and indeed it is looking cosmetically in absolute wonderful condition:
- barely a sign of use all around the barrel - I love this
- a little dust inside, as had to be expected
- slightly sticky, focus (feels slippery in times, the way it feels, when ham fisted repairmen use oil, to spice up an old lens for sale)
- it has the rear element protection shroud, which needs modification for digital Leica M bodies (no focussing beyond ~12-15m + no mounting, when focussed @ infinity)
I intend to:
- completely disassemble the lens
- modify the lens shroud to specs + repaint of machined surfaces
- clean dust specks
- clean any old lubrication from the helicoid
- relube the helicoid with correct lube
I am now in my holidays without workshop, but would like to collect some info from people familiar with this lens, to ease the riddles of proceed into the lens 🙂
Any input regarding the disassembly or function of outer visible screws is highly welcome 🙂
I will follow up this thread and post my proceeds, once back in the workshop.
I started down this path. Then I gave up and had Leica fix the shroud. I should have done that in the beginning.
You started down that path - lets share some info then ?
Which screw did what?
How far did you go?
Is the shroud a single piece, one can remove or is it part of the assembly, needed, for the mechanical function of the lens (I read a comment somewhere, that it is easily removed by the removal of three screws, once the lens is disassembled ?
… any input is welcome
Hi menos,
it is indeed a wonderful lens. It had a fault, trying to fix it
I broke mine! You can get the lenses out in one, but then....
So, give it in good Hands.
Kind regards
What is a Leica 35mm Summilux (pre-ASPH) vs. 2 lens ??
Gabor, this one here:
http://www.l-camera-forum.com/leica-wiki.en/index.php/35mm_f/1.4_Summilux_II
Why run the risk of breaking it? send it to Sherry and save yourself the grief.
The thread title was not "should I work on my 35 Lux myself?", but honestly thanks for your concern.
It is not my first venture in this kind of work and not the first expensive lens, I work on.
Part of doing such work is being informed, which can be helped by sharing info with others.
Hi menos,
Kind regards
Sem, please share some details ;-)
What happened?
What broke?
How did you proceed, to get the optical cell out in one?
Hi menos,
it is quite a while since I did this. But I remember that it wasn t so hard to get the lenses out. But then you can depart the the two parts as you can see. There is a pivot and once you get it out, the clue is to get it back in and hold the right scale of the lens for the rangefinder.
I hope it helps a bit.
Sorry my english isn t that good.
Kind regards
Hi menos,
why I did this. The lens jammed, when I focused near distance, and didn t come back. I better send in for repair, now it is broke and I sold the lens and keep the rest for me.
Kind regards
