Nice river/lake photos, how to....?
vegard_dino
2:46 PM
Hello all.
New to film and I need help.
I am jusing a Perkeo I.
So many nice photos of lakes, rivrs and ocean. But, how/what to do to get the "blurry" look on the wather?
With "blurry" I mean, looking like the wather is fog. Hope you understand what I mean.
I know, juse a low shutter speed, but, have tried that and it did not end up so good....:rolleyes:
All help is needed.
Thanks all.
You need several seconds of exposure. Typically this is done either at night, or with a strong neutral density filter.
To do this you will need:
1) the water to be in motion!
2) a tripod
3) a cable release
4) a longer shutter speed
To really achieve the "fog" effect, you'll need to use a minimum of 10 seconds or so, even for fast moving water. Obviously this means slow film and fairly small apertures, too. I would run a bracket using shutter speeds as long as a minute, depending upon the water conditions and the weather. Good luck and have fun!
What ferider said. The longer the exposure, the more "smoothed" out the water will seem. I have taken some long exposures at night (of sky and water) and, if I recall correctly, I was exposing for up to 30 seconds. The water was a lake and not very wavy. At 30 seconds, the lake looked like glass, if that makes sense.
Hello and thanks for the replys.
So, a stupid question.
To get a loooong exposure on these old camera, can I use B and hold the shutter realese down, use a remote, in order to get it long? Yes, I know I ask odd things....:confused:
A tripod is in my bag, so that part I have.
But, I will go out and try more, and yes, have fun testing these out.
And as you probably already know, take detailed notes on each and every exposure so when the film is developed you can clearly see what works for what you're wanting...
Not stupid; I use "B" and a cable release; for very long exposures, I lock the cable release. You don't want to touch the camera while taking the photo, only the cable release. The shot below was taken like this - around a minute or so.
Roland.
For a fast moving stream or river, 1/4 sec. or longer will. (most likely) give you the look you are after. For a lake with water washing over rocks, an exposure of 5 to 30 seconds is needed.
It is better to make these lake exposures using long exposures at dawn or dusk or during very overcast days in my experience.
Using a ND filter will work to produce the desired effect - but (to my eye) it does not look natural in a high contrast image where bright sunlight and hard shadows are present.
