nikkor q 200 disassemble
tomaas
2:31 AM
hello.
I need to dismantle this lens.
Does anyone know any forum or any place about lens repair?.
very thankful.
I haven't done this lens, but on Nikkors of this vintage, you typically have to pull up the silver lower barrel in order to expose the helical guides, which are accessed through a port on the side. Look for screws at the base of the barrel. You might have to remove the mount first. Typically 4 of the mount screws have to be removed, while the fifth should be left in place, since it holds the aperture spring.
On many, the entire inner barrel/optical assembly can be slid out in one piece by removing retaining rings at the front of the lens, but this model might not do so given its length.
Sent from my SM-G920V using Tapatalk
oh peterm1, incredible information, very complete, it seems perfect for me. thank you very much.
thanks also to dcshooter, yes, the entire inner barrel slids out in one piece.
