Nikon HC 5cm f2 lens woes
mrjr
12:10 AM
Hello all.. I'm looking for some input, and for an opportunity to vent.
I've had the lovely little Nikkor for a while, and I'm using it via a cheap adapter on my M6 mostly. I bought it because I was drawn to the Sonnar design, and from the few rolls I've developed from it, I've been very pleased to have it. I also bought it because I find 1m minimum focus distance so limiting as to be prohibitive—my use is mainly casual candids—and this lens boasts a very nice .5m mfd. Oh, and I don't care to spend $$$$ on an M mount 50... I just don't shoot 50 enough to justify or desire that.
So far, so good.
Allow me to describe my woes. The most minor of these is—wow! An almost 360° focus throw. Ok, I'll deal with that. Gotta be precise with a 50 up close and in poor light anyway.
The next problem I now suspect to be adapter related: the rangefinder coupling checks out at 3.1". Is this normal? Or could a cheap adapter cause this problem by interfering with the rangefinder cam?
This is probably the most maddening: that STUPID detent/short focus warning that stiffly interupts me EVERY SINGLE TIME I move in for a nice little portrait. Come any closer than 3.4", and boom! That hateful detent. There are no words and no analogies for how great this irritation can be, and it seems like this is what I encounter on more than half my photos with it. It really distracts from the simple act of trying-to-take-a-freakin-photo, and it gives me measureable anxiety.
What input do you have? Is it possible to have a competent repair person remove the detent entirely? Is there another lens that I could turn to for a price that's comfortably under $200 that offers similar imaging and can do .7m minimum focus distance? Honestly... what do I do?
Glad you can deal with that, because the other two issues can be resolved!
This is normal, and nothing to do with the adapter. These lenses were designed for screw mount cameras with a coupled RF that checked out at about 1 meter (a bit over 3 feet) so there was no point in designing them to focus couple any closer. But the lens can be modified for closer focus coupling by making a cutout in the lens mount as shown below. I did this cutout myself, but any decent repairman should be able to do it. With the cutout on the lens mount as shown, the limiting factor of RF coupling is now on the camera side i.e. you get RF coupling to the limit that the camera is capable of (about 0.65 - 0.7m on most M bodies).
Dead easy to fix this one. See that piece of metal held on by the two screws just above the infinity lock in the photo below. That is a spring which presses against a ball bearing, and that ball bearing is the cause of the detent. Try pressing on the spring while rotating the focus past the detent, and you'll see how it works. I don't remember if its possible to remove the ball bearing from the outside, but you certainly can remove the two screws and spring, and then bend the spring so it applies less (or no) pressure on the ball bearing when reattached, thus reducing or removing the detent.
P.S. you're lucky I just happened to have my Nikkor-H 5cm F2 and MP on my desk right beside my iphone 😉
Amadeo dedicated 50mm adapter + Kiev mount Jupiter-8.
But I would suggest just doing the fixes that jonmanjiro described. You will still lose the coupling after focusing closer than 0.7m. If you can live with that (and the aperture ring turning the "wrong" way)... this is your lens!
Fantastic! I was beginning to suspect that a hack to the adapter would allow the cam to travel farther. I may attempt to tackle the modification myself. Can I expect that the rangefinder would be accurate for focusing down to the minimum focus coupling on my M body?
Wow! That's great. I don't remember seeing that spring on my Nikkor, which is an earlier silver nose, but I'm sure it must be there. I'll check it out. I bet you're totally right.... I bet I can remove that spring--maybe entirely! That would make me a lot less suicidal (joke) when shooting with it.
Haha, Yes, I am! My thanks to you and to lady luck. 😉
Wait! Does the Jupe 8 focus down below 1m? I've always wanted to try one, but didn't want to take multiple $40 dollar gambles on getting one that wasn't abused and that focused correctly.
Sent from my iPhone using Tapatalk
keep in mind, that brbo talks of the kiev mount lens - that one doesn't have any means of focusing. it is up to the adapter to provide it.
so, just choose the right adapter, and it will do.
Oh!! The Kiev mount one. I didn't read carefully, but that makes sense now. Thanks.
Yes, focusing is accurate down to the minimum focus coupling on an M body. If you search through this site, I'm pretty sure there's a thread or two that explains in a bit more detail how to do the modification.
Brilliant. I'll search for that and see what I come up with. Thanks!
Also, UPDATE: I bent the detent spring on the bottom of the lens and it no longer engages the detent! You were totally right. My sincere appreciation!
there are two different versions of the lens if i remember correctly.
if you want to take out the ball detent there should be screws on the mount where you can detach the screw mount portion and just remove the ball.
on another version it is lacking these screws so i couldnt remove the ball or the mount plate. bending the detent metal part is a good idea though.
i did the modification on a nikkor 5cm 1.4 so it should be the same.
Excellent! 🙂
I dug up a couple of links that discuss the close focus coupling modification (which is the same for both the LTM Nikkor 50/1.4 and LTM Nikkor 50/2)! Make sure you have the right position before you start filing.
http://rangefinderforum.com/forums/showthread.php?t=73271
http://www.rangefinderforum.com/forums/showthread.php?t=56962
The benefit of hacking away at the threaded lens mount will depend on which M body you have. With an M3, for example, you will gain next to nothing. Unless such a mod is extremely well done, looking like the lens was built that way, you will destroy the resale value of the lens.
Check your camera body's minimum focusing distance before going for your Dremel tool!
Dez
OP already stated that he's is using it mostly on M6. On my M6 it was coupled down to a little closer than 0.7m.
The opposite problem
I have the opposite problem from the OP's. I have a nice Nikkor LTM lens which has had the detent cover plate removed. I like having the detent, and miss it with this lens. If anyone has one of these plates and the little screws to mount it, I would be interested in buying them.
Dez
