Nikon lens service questions
Disappointed_Horse
1:59 AM
I just noticed that my Nikon 50mm f/1.4 AI-S lens has, which I bought used LNIB about 10 years ago, has accumulated quite a lot of dust inside. This is a bit surprising, as I almost always have a filter and caps on the lens whenever I’m not using it, but be that as it may, I have not noticed any effect on image quality yet. I will be looking at my next set of negatives very carefully.
I have two questions:
  • At what point does internal dust start to affect image quality?
  • Who do you recommend to service Nikon manual focus lenses?
Thanks!
In my experience I've never seen a lens with enough internal dust that it affects photos. Maybe such a lens exists, I suppose it would reduce contrast, similar to what a sufficient amount of haze can do.
If I were to send off one of my SLR Nikkors, it would be to Pro Camera in Charlottesville (assuming you're in the US.)
Where do you put your caps when the lens is in use? Pockets can be quite dusty and can be a source of dust which transfers to the lens, particularly by means of the rear lens cap.
Never worried about dust inside a lens. Never worried about how clean the outside elements were. Did worry about over cleaning a lens and damaging the coating (not much of a problem with newer lenses but old habits die hard).
Go to the Nikon USA website and look for Nikon Authorized Repair Centers.
Thanks for the replies everyone. I had not thought of pocket lint/dust on the lens caps as a source of internal dust, but that makes a lot of sense. I'll be mindful of that in the future.
