jssaraiva
I have the Nikkor S mount 35mm f/2.5 and would like to use it on a Fujifilm X-Pro.
I've read (even from sellers descriptions) that "normal" S to FX adapters can't be used on wide angle lenses. On the other hand, Amedeo adapter to Leica M apparently allow 35mm 2.5 and so a further M to FX adapter could solve this.
My questions: is this two adapter combination the only solution? It is a very expensive solution. I also have the 50mm 1.4, so that would only be adaptable with an Amedeo, but at this point this is not my main goal.
Thanks in advance for any input!
José
José
