Nikon S 8 digit Serial Worth?
k2adir
12:06 AM
Hello,
I have this rangefinder, recently I learned that 8 digit ones worth more compared to others.
I have done some research online and the price point isn't very defined. It starts at 700ish and goes up to 7K us dollars. Which is very hard to make a guess.
I wonder If anyone here has an idea of for this rangefinder's worth.
Camera works and speeds are accurate including Slows and B
Fast speeds (top dial) works like it should.
thanks
nikon s 8 digit
nikon s 8 digit
I looked your camera up in rotolonis nikon rf book
looks like there were about 1230 made of your type
there were 2 separate 8 digit groups
the first is very rare and the last number is always 1 , they were produced and the 1 was added to the top plate and back number and are the high value ones
yours is the second type , pretty much a continuation of the standard sequence 609xxxxx with eight numbers instead of seven . as I said 1230 produced in this group .
the number on the inside of the back should match the one on the top plate,
the shutter needs adjustment to cure the problem you see and it is common with old nikon and leica rf cameras .
as far as value I dont know , the original owners name engraved on the front plate affects that .
nice camera to have though
thanks for these!
The film back serial number does match.
i hate it when people write their name on cameras... My Nikon S3 has the same problem
- Edit
shutter works fine now. I guess very cold temperature made it lazy. Room temperature solve that problem
