Nikonos IV advance lever stuck
schlops
10:57 PM
hey folks,
I hope someone has a solution for my problem. I have a Nikon IV that works completely fine but now that I finished a roll and checked if the shutter works correctly the advance lever is stuck. It won't move at all.
I opened the back and fired away a few times with no film it, shoot, advance, shoot, advance and so on. All of a sudden the advance lever wouldn't move anymore and is completely stuck.
Is that a known problem? Is there an easy way to fix it?
Thanks in advance,
Alex
Southern Nikonos is a long distance for you but I think I remember that the Nikonos IV is made up of Nikon FE parts so a local repair tech might be able to help. Joe
Mine has the same problem, but then it's a flooded wreck. I went through the manual, but couldn't find anything that says the shutter is battery dependent, though the presence of a Manual setting on the speed control ring suggest it is so. So maybe your battery is too low, and the shutter has locked up, which would keep you from advancing the film. Just a theory.
PF
PF
It works (worked) fine without battery before :/
Last night, after I wrote the previous comment, I dug into my camera to see if there was any way to trip the shutter from inside.
I took the cover plate off that is right below the viewfinder (after opening up the back), and was greeted with the usual sight of all the dried salt that had accumulated there. Surprisingly little corrosion though.
After doing this, I rotated the Mode Selector ring on the winder to see how it reacts with everything else inside. About the only thing that changed was when it was on R (rewind), it freed up the film sprocket shaft. I could see a small brass lever controlled by the Mode Selector pressing horizontally against a white plastic vertical one coming up from the shutter area.
The white plastic lever would move when the shutter button was pressed, but only so far as the brass one would let it, so the brass lever is actually moderating the movement of the plastic one. This is all hard to see because of a couple of rheostats in the way, so use a bright light to illuminate the interior.
Since this didn't really get me anywhere, I kept looking for other levers. I turned the camera so I could look down into the place where the plastic lever was poking up from, and saw another lever, made either of aluminum, or plated with nickle. I used a dental pick to press down on the lever, then I was able to move the winder through a full rotation. I heard what sounded like a release of the shutter, and was able to wind the camera one more time before it locked up again. I did this cycle once more with the same results.
So the third time I tried it, I kept the film pressure plate open so I could observe the shutter operation. As I wound the camera, the second blade set would rise like it's supposed to, but then it would release as soon as it got to the top. My diagnosis then would be a failure of the shutter to retain the second blade set in a cocked position. Don't know if this is an adjustment problem, or worn/broken parts, but it's not something for a home fixer upper to work on.
PF
Bob from Southern Nikonos told me via a short email conversation
"almost certain internal leakage/rusted parts! And, you can not correct from there."
