No rangefinder Zorki 1, similar to Leica Standard model
davidnewtonguitars
Family Snaps
4:39 AM
I am interested in shooting with a camera similar to a Leica Standard model, converted from a Zorki 1.
I am pretty handy and think I can build it myself, but am unsure about certain parts such as a finder and a speed indicator "bump".
Does anyone have any advice?
L std from FSU
L std from FSU
Someone on this list had Oleg build such a conversion.
Don't recall if the project was successful.. or even completed. :bang:
You might try searching the archives, or you could try checking with the builder - http://okvintagecamera.com/
I am wondering if the cost of making a Leica out of a Zorki might be no cheaper than a Leica standard, at around $800. You know, by the time you round up the finder and maybe pay a machinist to do a few thing? Hidden costs might add up.
It's not all that difficult,
You will have to find the speed escapement cover from a standard (DAG had one last I looked) and it will likely require a new mounting hole in your top plate.
You'll need to fill a few holes where the RF assembly attaches and the cam arm drops into the crate.
if your motivated, go for it!
Any cheap FED/Zorki body you buy from the FSU will likely require new curtains as well as a good internal cleaning, adding to the complexity of your conversion. Although there is a ton of info online regarding this process, you may investigate if this is something you would be comfortable doing.
I've seen a conversion, and I think there is no reason to do it, honestly. You end up with a worse camera.
Here is the outcome of my efforts so far, I am ready to test my distance guessing and aiming skill.
