Chad
I'd like to get a lens cap for my new Nokton 50/1.5 that fits the lens without the hood. It appears that the outer diameter of the front lip is between 53-54mm (53.5mm?). The inner diameter is 52mm. Are there any lens caps I can get that will fit this?
thanks
Chad
thanks
Chad
ferider
Chad,
just use an empty 52mm filter ring. Works well. The Nokton doesn't
vignette even with two filters.
Roland.
Roland.
aad
Not so new now.
I did the same thing. The hood on thhe Nokton partially blocked one rangefinder window. Focusing in low light is tough enough!
Chad
Thanks everyone.
Chad
Chad
P
polaski
Guest
Try a screw-in cap
Try a screw-in cap
I've completely switched to these (match your filter size) because the don't fall off as easily and wif they do, they are metal and I have a better chance of hearing it hit the ground.
Try a screw-in cap
