Nokton 50mm 1.1 focus ring/tab
Disrespective
9:46 AM
I've been tinkering with my new 50mm Nokton and am finding my ability to focus quickly less than ideal compared to the 28mm Nokton with its nice wee tab.
So I jumped on the PC and designed my own.
Have a look here: http://www.thingiverse.com/thing:9078
The source files are freely available to anyone, all you have to do is have a 3D fabricator of some type to print it out.
I'm going to try and make a thinner version in the coming weeks so will update the images and files if i'm successful.
Blurb from Thingiverse:
This is a focus ring attachment for a Voigtlander Nokton 50mm 1.1.
I found that after using the 28mm Nokton 2.0, the 50mm 1.1 was tricky to get used to being able to focus as quickly. I suppose over time that this could get easier as I got more accustomed to the lens but decided to do something about it in the mean time.
The tab is vaguely modeled from the 28mm focus tab so should be a very similar size when printed and in use.
The ring should slip onto the lens from the rear as it will not fit over the aperture ring due to fine tolerances. The fit will be very slightly snug and seems to be enough to hold itself in place. That being said, it is still loose enough that it could get knocked off the lens if you aren't careful. I didn't want to put stresses on the lens barrel.
I'm not inclined to use any adhesive but perhaps some blu-tak (or equivalent) under one or two of the scalloped sections of the ring would be enough to ensure a more solid feel.
If anyone is in NZ I can probably print one out for you for a nominal fee and send it off. I'd hardly call it a perfect solution or alternative, but could help someone.
*shrug*
