Note To Self: The Fixer Comes Before The Fixer Remover
wgerrard
9:28 PM
My adventures in b&w processing have moved onto their second roll. I have a question about the shot below.
I'm using an all-Kodak Xtol regime: Tri-X 400 shot at 400, Xtol, stop bath, KodaFix, hypo clearing agent, PhotoFlo. This photo was processed with Xtol 1:1 for 7-1/2 minutes at 72F, per the Kodak PDF's instructions.
The thing is I jumped from the stop bath to the hypo clearing agent, forgetting the fixer. (No, I can't explain it.) I caught it immediately, poured the hypo clearer back into the beaker, rinsed the film in water, added the fixer, and kept going. Most of the negatives looked OK, but a few did not, showing water spots a cloudy areas.
In the shot below, I see cloudy regions in the upper right. The marks on the bricks to the right of the bike may or may not be splotches. It was late afternoon and a bright sun was shining in from over my right shoulder. Minimal PS tweaking happened after the scan.
Is what I see the result of my little fixer-hypo clearer kerfuffle, one too many water rinses (i.e., getting the hypo clearer off after the screwup), or something else?
Looks ok to me. The darker areas on the bricks might well be ON the bricks. I have several recent negatives that show things I didn't or couldn't see at the time I took the picture. The street is very even. The brick wall behind the low building is very even.
It could have been worse. Fix before developer is FATAL!
As long as you were using an acid stop bath it should have halted all development action at that point. Many of us just use a water rinse, which doesn't; it merely keeps the fixer more acidic and longer lasting. The distinct vertical alignment of what looks like a shadow on the bricks towards the right couldn't have happened from a chemical screw-up.
As long as no light reaches the film before fixing, it won't matter (other than that it will extrend the development time by a small amount, and that you might get a slight hazing from cross-pollution with hypo if the clearer was already used).
Hypo clearer is sodium sulfite, which does not interact with developers in any negative way - indeed, it is a extremely widespread alkaline in photo chemistry and the main component, going by weight, of most popular ready-mixed developers. Besides, a sulfite bath between developer and fix is a regular contrast reducing technique.
Yep, there's a wash in there. If I don't use the clearer, how long does the wash need to be? 20 minutes? I'm giving it 5 minutes now.
That's reasonably close to the regime I've followed. I use Kodafix for 7 minutes after a test with Tri-X, Kodak's hypo clearer for a minute, a 5 minute wash, and PhotoFlo for a minute.
I know opinions on PhotoFlo vary, but my negatives so far have been much cleaner, after carrying them through two rooms to a closet for drying, than the negs I've been getting back lately from some of the usually recommended processors. I don't keep a dust-free place, as my vacuum can testify.
After I use up my Xtol, I think I'll try Delta 100 (bought some recently) and Ilford chemicals.
