Chris Flurry
Hello i am new to your forum and was hoping you guys could help me with something. I recently purchased my second Retina IIa and was checking it out toady when something odd happened. The Shutter will fire fine unless you switch the flash sync switch from X to M. When the flash synch switch (the green switch on the lens) is in the M mode the shutter clicks but does not fire. Any Ideas? Does this indicate a problem? I think I'll just keep using the camera but it is odd.
Thanks in advance,
Chris Flurry
Thanks in advance,
Chris Flurry
Chris Flurry
And more Problems
And more Problems
Now the shutter is stuck open at the slower shutter speeds, hmmm looks like I need to send it somewhere. Any recommendations?
And more Problems
Sounds like it needs a good cleaning. You can check with Essex camera in New Jersey.
http://essexcamera.com/
