Off-film flare?!
Dante_Stella
Rex canum cattorumque
11:29 AM
I am stumped. I am experiencing a 3mm wide circular section flare (like a rainbow; the circumference of the section is about 10mm) in the upper right hand corner of images - and just occasionally. It has a fairly sharp edge to it and looks like a 1.5 stop exposure increase. These are the parameters:
- Only happens with one lens, a symmetrical medium format wideangle
- Light source of all affected pictures is behind the camera
- It is not specific to any contrast filter
- Lens has no missing blacking or damage to the rear shroud
- There are no light seal issues with the camera
- Changing bodies does not eliminate it
- It only happens with TMY; does not happen with color film or TMX
- It seems to track the contour of the rear element/shroud
Is it possible that light is being reflected back to the lens from the film and then ghosting?
Dante
Would be helpful to know the camera and lens, and see an example shot.
I have seen, on a view camera using an ultra-wide lens that places the rear element really close to the film, reflect light off the film, back to the rear element, and then back to the film as a semi-circular section of coma-like flare.
Are you using a wide lens where the rear element is close to the film /sensor?
Isn't that what the anti halation layer is supposed to prevent? Or are you working with a special film type [edit, just saw that you are using standard films]
Larry - it's a 50mm Fujinon for 6x9. I'll get a picture up, but what you describe sounds exactly like it.
Dante
Larry -
Here's the most egregious example, with a somewhat side-lit light source (but not so side-lit that it would flare other lenses).
Dante
