Dante_Stella
Rex canum cattorumque
So as I recalled, when I had one of these adapters before, lenses would hit infinity focus just before the infinity mark.
So I read some accounts of other people's experience, some of which were the same and some different.
My second copy of this adapter again back-focused when the lens was set to its hard infinity stop (and I repeated this with many lenses). I pulled out a micrometer to see what the difference in lens extension is between the infinity marking and actual infinity focus. It looks like it's almost exactly 0.1mm, which seems like quite a lot (0.04 is where focus starts to be off). And measuring the adapter, it at least seems to be exactly the right size (10.1mm) to make up the difference between Fuji register (17.7mm) and at least one Leica register (27.8).
Is the real issue that Fuji used the wrong Leica dimension (using 27.8 front film rail instead of 27.95 expected image plane)?
I have an X-Pro1 - has this worked better with the X-T1?
Thanks,
Dante
Thanks,
Dante
