BillG
what film did I load?
I have a Leica IIIf with slow speeds off. It needs a CLA and I have an estimate of $300 to get this done in Toronto.
My question is this: is it all right to keep shooting at normal outdoor speeds like 1/500, 1/250th or am I going to damage the camera by continuing to use it without the CLA?
denishr
アナログ侘・&#
I don't think there's danger of damage if the slow speeds are off - are they slower, or what?
Probably the curtains need tensioning.
$300 seems high for that, though
Denis
Denis
BillG
slow speeds off -- by off I mean way off the time they should be.... as in much longer. The $300 is in CDN from Kindermans. CDN was about .75 US at the time of the quote. CDN is now up to .82 cents US.
FrankS
Registered User
Bill, where in Toronto did you get this estimate?
BillG
a fellow PN Toronto Leica Forum fellow talked to Kindermans on my behalf back in August/September
FrankS
Registered User
Have you heard of Kominek Camera? Russ is a real old-time camera shop owner, located at College and Younge St.
P
pshinkaw
Guest
My IIIf is in a local shop now for a curtain replacement (both). The estimate I received was $180 US plus local taxes (8.25%). You should get some comfort in knowing that your Leica isn't leaving the country without you. That's got to be worth some $$.
I think the slow speed mechanism on the IIIf is basically bypassed when the front dial is set at 1/25. That's the default setting when you are using the high speed dial.
-Paul
-Paul
BillG
thanks for the lead, Frank
Paul, I think you are right. I am not really a 1/25th kind of a guy. I prefer enough speed to compensate for my sometimes shaky hands. Then there are days I am steady enough to think I could do neurosurgery
P
pshinkaw
Guest
My 1/25 days are long gone too, But I try to keep up with all of the possible ways to avoid sending a camera in to the shop. foras long as possible.
-Paul
-Paul
