Olympus FTL
10:10 AM
I have an Olympus FTL and the curtain is uncontrolled, where I can fix and speed in that place to make such devo graduation, and do not know how to control the speed, please help Thanks
The speed timer is located under the floor of the mirror box, but the only way to reach it directly is by removing the mirror box from the body. You may be able to remove the bottom cover, then remove either the tripod socket or the battery box to create an opening so you can spritz some cleaning solvent onto the gears. I have some notes & sketches on the FTL - email me at rick.oleson@gmail.com if you'd like a copy.
