Olympus XA - Realignment of needle
jamesj
4:03 PM
So I had to take the cover off my XA and when I put it back together the inside needle is acting all crazy. Im not sure if there is a way to fix this. It was working fine before. It seems to fire ok and the speeds seem fine just the meter inside.
any help?
- james
im thinking it might be a electrical issue, I noticed that a solder piece connecting the wire to the board came loose, the wire is still connected to the board, but not making a direct connection. So that may be it.
I think, like some above have said, you have a short. I had a similar issue when cleaning the RF, make sure those wires that solder to the speaker on the top of the RF cover are not having the red touch the black. It might take some time, but I think that was it. When mine was having wire issues the needle would drop every time I moved the focus, go figure. Good luck!
