OM2n Light Leak?
Perks
7:14 PM
Does anyone have any theories for these presumable light leaks?
[url=https://flic.kr/p/25s6SEQ]Light leak by illformation, on Flickr[/URL]
It is bulk loaded (by me) HP5 shot in my until recently no-worries Om2n
So I ma not certain if it's the film can or camera. the regularity of the leak suggests camera to me.
If it's the camera, can i fix this myself?
I will of course, load some more film and test it out, but just I processed and scanned these yesterday.
Thanks,
Andrew
Since it is on the perfs, it is coming from the back of the camera, upper side. Does the camera have any deteriorated light seal on the upper side? Run a strip of black tape across the top of the door and shoot a roll.
I usually buy self adhesive black felt from any arts and crafts shop, usually a A4 sheet for a pound. I remove the old seals and replace them with that. Works well. My OM2 had the same issue.
Or scrounge an old empty cassette from a lab and use its light seals again when cut to size. It worked once for me when I was away from home and had that problem...
Regards, David
Thanks everyone for your thoughts.
The seals are pretty degraded, but have been for some time and it hasn't been a problem.
I'll check with and without tape.
I'll try find some self adhesive felt or order a kit if that doesn't work.
Will have to check the prism issue a.t the same time.
I appreciate the help,
Andrew
Thanks for all info here. I have just bought an OM-4 and seals look damaged too. So I might do those tricks mentioned to be safe.
