Omega C-700 Questions
rover
Moderator
Staff member
8:08 AM
I just posted this over at Pnet and thought I would ask the same question here.
Some times ebay happens.
Well, $60 later I am the proud owner of a brand new Omega C-700 and shortly will be spending time in my bathroom with the lights off for the first time in 20ish years.
The instructions for the C-700 though are not very explicit so I have a question.
I have also purchased the heat reducing glass for my enlarger. No instructions though of where to place it. It makes sense that it be positioned under the bulb above the condenser. That is where I now have it, but, wonder if someone can confirm my decision.
Also, I have read else where that negative carriers for other Omega enlargers can be used with the C-700. I have read that it is the B series carriers that can be used, and other places state that D series carriers can be used. Does someone know for sure which other carriers can be used with the C-700.
Thank you
I have bought the 6x6 negative carrier for the B22 and used it with the C700. Never tried the heat reducing glass though!
Good luck!
Nancy
The glass goes between the bulb and top condenser. If memory serves correctly, it goes into the same holder as the filters. Any way the location is under the bulb.
