Mamiya Lenses
Mamiya Lenses
Hi Laurent,
Thank you for the kind words about my website.
🙂 Unfortunatley, presently there are no photos on my website taken with my Mamiya 7II.
🙁 I hope to remidy that shortly. Most of the images on my website are taken with either my Leica R series SLRs or with my Linhof Technikardan 45S.
I do not have enough experience with the lens hood on the 65mm Mamiya 7 lens to comment about lens flare. However in most instances it should certainly do an adequate job. For your purposes, this may be the ideal first lens to get for the camera. Many Mamiya 7 photographers chose this over the 80mm lens. Yes, the lens and the hood do protrude into the lower right of the viewfinder. This is a bit of a nuisance, but if you check the frame (and around the frame) of the area being photographed, you can deal with it.
🙁 Obviously, checking the frame will be easier if the camera is tripod mounted rather than being hand held. A Mamiya 7 with a 65mm lens should prove to be a light and rather potent film based package with such a large negative/transparency.
I would not really suggest the 43mm or the 50mm lens as the first and only lens for the camera unless you find that you use a 21mm or 24mm 35mm lens to such an extent that you feel the need to have such a wide angle lens as the first lens. Though, this is the realm of the Hasselblad SWC. However, either of these two lenses would make a very good second lens for wide angle photography or someone that specializes in wide angle photographs (much of my work relies on wide angle lenses; I probably use my 24mm Leica lens or my 90mm f6.8 Rodenstock Grandagon N [for 4"x 5"] lenses most often for my landscape photographs).
Additionally, as I noted the 43mm and the 50mm lenses will require the included optical rangefinder for framing that is not required of the 65mm lens. Also, as mentioned, you will probably find that when and if you try a 43mm lens on the camera it is a bit more difficult to control perspective than with the 50mm lens. Experience with 21mm and 24mm 35mm SLR lenses will prove invaluable to the understanding of the perspective effects that may not be observed in the optical rangefinders (must try to keep the camera level unless the desired effect warrants the results). Also, with such a wide angle lens, the foreground, taken with a 43mm lens, will loom large and there may appear to be a tremendous distance between foreground and the rear of the image.
For myself, with my Leica SLR cameras, I find that I carry my 24mm lens more than my 21mm lens (but this is partially attributed to the filter size differences [for carrying filters that fit other lenses or additional step-up rings]). However, for the Mamiya 7, if I am trying to save a little more weight and am contemplating even a wider angle of view, I would not hesitate to carry my 43mm lens Mamiya 7 lens as opposed to my 50mm Mamiya 7 lens. Also, both the 43mm and the 50mm Mamiya 7 lenses have a 67mm filter size.
Rich
richard@nelridge.com
http://www.nelridge.com
