colyn
ישו משיח
I found this lens in a local camera shops junk box with case, caps, hood, and finder. It's somewhat heavy for a lens of its size.
Left the store with it after paying $20 but haven't had the chance to try it out and was wondering if it is a good/bad lens..
xayraa33
rangefinder user and fancier
it is a great lens.
I hardly ever use this lens, somthing about a 135 focal lenght on a rf camera does not make a lot of sense to me.
John Shriver
Fine lens. Certainly obviously better than my 1946 coated Hektor 135/4.5. But, it makes the camera very front heavy. One of the elements is very thick.
The Canon 135/4.0 is smaller (40mm filter ring), but no lighter.
Kim Coxon
Moderator
For $20 it is an exceptional lens!
I have the later black version. I find I don't use this leength very much and therefore it is not worth paying a lot for it. If you really want to make use of it, the Canons prior to the P with the variable mag finder work wonderfully wth the 1.35 setting.
Kim
Kim
kb244
Damn you, I need to find something like that... (lol been look for a tele for my Canon P for a wee bit now)
W
wlewisiii
Guest
Every thing Kim said times 2. I have the black with proper hood & external finder. It makes a heck of a package on the CL let me tell you
but it does produce wonderful images. For $20 you got a heck of a deal.
William
William
Kim Coxon
Moderator
I have the case as well.
wlewisiii said:I have the black with proper hood & external finder.
William
colyn
ישו משיח
xayraa33 said:it is a great lens.
I've used my Tele-Elmar on my M6 a lot lately. Found it gives me the tight framing I need for some shots.
I may or may not use it much but I couldn't pass it up at the price. This way if I need it I'll have it.
colyn
ישו משיח
kb244 said:Damn you, I need to find something like that... (lol been look for a tele for my Canon P for a wee bit now)
The owner of the shop goes to a lot of estate sales. He'll buy photo gear for next to nothing and throw it in a box which I'll pick through from time to time.
Just got lucky today.
xayraa33
no, for 20 dollars no one in their right mind would pass that up.colyn said:I've used my Tele-Elmar on my M6 a lot lately. Found it gives me the tight framing I need for some shots.
Bill58
Native Texan
They seem to be very numerous in most of the webshops for little $$$. Why the number I don't know. The latest black version is very sharp.
colyn
ישו משיח
xayraa33 said:no, for 20 dollars no one in their right mind would pass that up.
But I've been told I'm not in my right mind!!
harry01562
Registered semi-lurker
Not a scarce lens, and certainly not a lightweight one. That said, it's sharp and very well made. You got a nice buy, worth 4-5 times what you paid.
There is also a chrome 3.5. That one has a front element that can be removed and used in a focusing mount on the Canonflex, the first Canon SLR. Of course, it can also be used on the later models, but no real need for it..
The late black version is also a very nice lens, and a bit lighter. It's one of the few 135's that I do take along on occasion.
Harry
Harry
Gabriel M.A.
My Red Dot Glows For You
This would probably have to be the steal of the year, if your lens is in at the very least "good" condition (no scratches on glass, no fogging, it focuses correctly...well, all other cosmetic conditions be d@mn3d)colyn said:Left the store with it after paying $20 but haven't had the chance to try it out and was wondering if it is a good/bad lens..
I have the black version, and I like it a lot, I hardly use it, but it is fantastic. The chrome version must be heavy, like others here have said, but optically, I'm certain it is the same. I don't even use the lens hood on it, it's how reasonably resistant to flare it is. Wide open it is very nice, and stopped down is even better.
$20... wow.
W
wlewisiii
Guest
We forget, sometimes, that the 135 was the 2nd most important fl to most people back in the day. The first lens made by Canon was a 135/4 that started trial production in 1941.
Modern RFer's don't seem to have much use for anything longer than ~90mm but back in the day, the 135 was often the second lens bought and frequently was the only add-on lens bought. It doesn't hurt that it's a relativly easy to design length, but it still behooved the companies to make good ones. Which leaves many nice & cheap ones for those of us who _like_ that FL...
William
William
SteveM(PA)
Poser
We'll have apple trees in the spring...
Mine crapped out yesterday...focus got progressively stiffer, and finally it completely "seized"
D ), only seconds after I got this last series, with the R-D1...
Kim Coxon
Moderator
Sounds like a relube is in order.
Kim
Kim
SteveM(PA) said:Mine crapped out yesterday...focus got progressively stiffer, and finally it completely "seized"D ), only seconds after I got this last series, with the R-D1...
SteveM(PA)
Poser
Kim Coxon said:Sounds like a relube is in order.![]()
Kim
I don't know...it is ungodly tight...when I can get it to closest focus (fully extended) there are now deep scratches visible on the barrel. Maybe something got lodged in there somehow. Just prior to this, it was silky smooth, although heavy, of course. And it doesn't seem readily apparent how to separate the focus ring from the mount part.
Anyway Colyn...it's a fine lens. I use (used?) mine all the time. Half the battle is just getting it to your shooting locale. There are many more pix with it in my gallery.
Think I'll look for a black one next. Knew I shoulda bought Joe's way back when...
W
wlewisiii
Guest
SteveM(PA) said:Think I'll look for a black one next. Knew I shoulda bought Joe's way back when...![]()
Glad you didn't - as I did :angel: and it is a very sweet specimine of the type
William
SteveM(PA)
Poser
wlewisiii said:Glad you didn't - as I did :angel: and it is a very sweet specimine of the type![]()
William
Aww man!
