optical viewfinder Mamiya Super 23
caspert79
Dutch User
3:31 AM
I recently bought a Mamiya Super 23 with a 65, 75 ,100 and 150mm.
For the 65 and 75mm you need a special viewfinder. They were not included however. Does anybody know where I might find them?
They show up on fleabay from time to time. The 65mm is about the equivalent of a 28mm in 35mm cameras, so if you have a separate viwefinder for a 35mm rangefinder, you should be able to press that into service. The 75mm is about the same as a 35mm lens for a 35mm camera. Again, if you have a 35mm rangefinder with an auxillery finder for 35mm lenses, that should work pretty well.
You might also try such places as KEH or B&H. Good luck. You are going to like using that camera for the bigger negatives/slides. The lenses are also quite sharp.
