OT: Prefer Leica R6 or R7 (for actual use)
julianphotoart
No likey digital-phooey
11:22 PM
2,567 miles from Toronto
This is my second OT post of the day, but where else can I ask such OTW questions?
I have a GAS problem, but it's not RF-related this time. I really gotta have a "new" Leica-R camera to go with idle R-mount lenses. I don't want the R8 or R9. So I assume the preferable second-hand choices for actual use are R6/R6.2 if I want mechanical or R7 if I want electronic. Whaddya think?
That is a very very difficult question, usually easily answered by how much money you can spend.
I started with an R4, then upgraded to an R5. I loved the R5, but needed to have speeds above 1/2000 if I wanted to shoot wide open outdoors. So I saved up and upgraded to the R8, which has a top speed of 1/8000 sec. I know it looks grotesque at first, but believe me, it fits very nicely in your hands (provided that your hands aren't "too small").
I've had the opportunity to use (not own) an R6.2; very very nice, but you are definitively paying big bucks for the difference between an electronic shutter and an all-mechanical shutter (which the R6.2 has).
The R5, R6.2, and R7 look and handle virtually the same, except that the R5 doesn't have mirror lock-up.
Anyway, I think I'm repeating info you already know.
I think, honestly, if money is not the concern and you like to shoot wide open (like I do), go with the R8/R9, which used may be about the same as a used R6.2, and in the case of the R8, maybe even a bit cheaper. If money is a concern, then go with the R7. It's a lighter camera than the R8/R9 too.
Or...you could flip a coin. Or buy two! (I had a Leicaflex SL2 as a backup for a while).
Oooohh: one major advantage that I can think that the R8/R9 could have over the R7/R6.2: the light seal for the film cartridge window. It deteriorates with age, of course, but you won't know it until you see a light leak in your pictures. It did happen to me with my R4. Easy to fix; hell of an annoyance --- they should have just designed the R3/R4 cameras themselves...that's what you get...
The viewfinders on the SL and SL2 are still unbeaten for clarity IMHO. Don't exclude them on mere age grounds, so long as your 'idle' lenses aren't either R-cam only or ROM, they'll work.
Really it comes down to whether you want to have an auto-exposure mode as an option. If so, then the R6 and SL models rule themselves out. Gabrielma has given you the low-down on the handling.
If you don't want an R8/R9, that's certainly fine, but any particular reason? It's really a great camera if you have laid a hand on one...
