Overexposure? Over-development?
Mjd-djm
11:08 PM
UK
I'm having a few issues with both my M6 and M6 TTL which I think must be a metering issue. Obviously I'm trusting the cameras meter too much and every roll I get a couple of shots like this which are flat and very grainy. My guess is overexposure which the scanner has tried to auto-correct. I never used to get this with Kodak film so I wonder if it is a weakness of Ilford film???
This was HP5+ developed in LC29. The rest of the roll was fine except for say 3 shots at the end. this has been driving me mad for a while so any advice would help.
dateposted-public
https://www.flickr.com/photos/mjdmjd/46651363635/in/dateposted-public/
Check your M6's meter against your M6 TTL using a similar exposure scenes that are in question. If they are the same then get a good hand meter and check against that. Also, you should turn off the auto-correct on your scanner and adjust by hand.
I've used some Ilford film and I don't really see any 'weakness' when compared to Kodak
You should be able to read a newspaper writing through the darkest part of the negative. This is an easy development check. But you should tweak your development further if you aren't 100% happy with the results.
There many testing procedures in photo books and the internet. These are really complicated and require a lot of time.
Chris Crawford here on RFF has some great tutorials for your problems:
https://www.youtube.com/watch?v=Y5xBHKGVOB8
https://www.youtube.com/watch?v=bwFaOJcdaiQ
