OVF frame line brightness with legacy lenses
Philip Whiteman
8:42 PM
Forgive me if this has been answered elsewhere on the forum, but I am new to the X-Pro 1 and wondered if there is any way the OVF frame line brightness can be adjusted when using M lenses with the Fujifilm M mount adaptor. (The default setting seems to be a compromise setting, somewhere between the bright and dim extremes you see when using native Fuji lenses.)
The other oddity is than when you select either of the fully user programmable extra lens options, as I did for my 90mm, the OVF shows coloured frame lines - in this case a rather low-contrast red that is pretty much invisible in bright sunlight.
Doh! I discover from the Fuji X Forum that all you need to do is summon up the menu with your eye to the viewfinder and the OVF engaged and tweak the LCD brightness setting. logically - too logically for me - when you are looking at the big screen on the back, the same menu function simply adjusts that LCD's brightness (and not the OVF frame lines).
