Panasonic GF2
mdtrpt
2:18 AM
What non Panasonic lens' can I use with a GF2? I have a Zeiss 28mm that I cannot use and would like to find something similar.
Any micro 4/3 lens will work as natively as a Panasonic-branded one. M-mount lenses will work manually, with an adapter... including Zeiss ZM lenses.
Keep in mind though that at for the longer lenses, you will probably need to buy ones with image stabalization built in. Olympus doesn't put it in their lenses sense all their Micro four thirds have it built in.
Bill
What mount is the Zeiss lens you have? You should be able to use an adapter. I use all my 35mm lenses of all mounts with my G1 and G2 with the exception of Miranda lenses which I can't find an apapter for.
