Pano with M8
naruto
GASitis.. finally cured?
2:00 PM
So, I was shooting with the M8, and a fellow photographer asked me if I ever used the "C" mode. So, I thought why not use it for a pano. Metering using multiple points and fixing at an average, I put it on the "C" mode and fired as I swung around "manually".
Here are the shots: M8 + Ultron 28.
Bixby Bridge
And, one from the other side. Sorry for the larger image, but it really needs to viewed big.
I do this sometimes, works better with lenses 50mm and above...
25mm Zeiss on M8, not easy to do with moving elements...
Larger
50mm Hexanon on M8
