Pentax 35mm ranger module ident?
jaydag71
12:30 PM
hullo, all, I am hoping that the image I inserted will show up, there are more under the general url if anyone wants to check out the rest,, there are about 5 if them I think. The ranger was pulled from an older pentax 35mm still camera- I didn'y bother to copy down the model number before I tossed trhe shell and everything else I didn't want, so that was dumb.
I am trying to find out some infos about the manufacturer of the infrared ranger, specsheets if possible- I want to interface the unit with a microcontroller for a small robot project I have been workign on. The ranger has a Mitsubichi micro in the rear, but most of it is shielded so I cannot view the exact device# without pulling the shield (which I am prepared to do if needed, but thought to rtry a few forums first.....)
So, if anyone has any advice as to the particulars of these modules, links to addititional infos , or anything I would be greatly appreciative of that! Thanks in advance, jd
5f21
just in case the image insert doesn't show, here are the links to the pix direct::
http://tech.ph.groups.yahoo.com/group/SeattleRobotics/photos/view/5f21?b=4&m=s&o=0
http://tech.ph.groups.yahoo.com/group/SeattleRobotics/photos/view/5f21?b=5&m=s&o=0
http://tech.ph.groups.yahoo.com/group/SeattleRobotics/photos/view/5f21?b=7&m=s&o=0
http://tech.ph.groups.yahoo.com/group/SeattleRobotics/photos/view/5f21?b=8&m=s&o=0
there you go......
