TXForester
I put the first roll through my camera today. Everything seemed to work OK until I reached the end of the roll. Then the film winder just kept running. I turned the power off, then back on and the winder started running again. I'm betting it should not do that, right?
mwoenv
After the last frame, the winder will advance the film to the end which takes about two seconds and then the winder stops.
TXForester
That is what I thought would happen. Wonder why mine kept running. Maybe whatever senses the end of the roll coming off the spool failed?
mwoenv
According to the Problems and Remedial Solutions section of the manual: "Should film residue or dust collect at the contact point (for film detection) located on the pressure plate side of the film holder, the motor will continue to rotate idly after all remaining frames have been exposed. However, in approximately 30 seconds the motor will stop turning. When the motor stops and the ON-OFF operation of the main switch is repeated, the motor will again be activated in idle rotation; however, avoid doing this, since it may cause problems with the film winding mechanism. After switching off, remove the film holder and clean the contact point of the pressure plate."
So remove the film holder and make sure there is no dust in the film chamber or on the film holder. It sounds like the motor keeps going because the dust makes it appear there is still film to be rewound (the 2-4 seconds of winding after the last fame is rewinding of the film, not advancing of the film as I had said).
Hope this solves the problem.
The manual is available on Butkus' orphancameras.com site.
TXForester
I have a manual, but missed the section you quoted. Many thanks.
And I love that website. I have downloaded several manuals from Butkus and keep them on my phone for easy access. Sure beats carrying several manual booklets.
