rbfigueira
My Pentax ME Super has developed a 'sleepy head'. After being out of use for several minutes (In my case is more or less 4 minutes) and then cocked the shutter won't fire, has to be re-cocked once or twice and then all is fine, until the next idle period.
Example: I advance one frame (cocked) and fire, I can do that over an over ... but if I not use the camera after the 3 or 4 minutes... I advance one frame but the shutter won't fire !! I have to advance one frame again to fire!
Any easy way to fix this ?
Thanks
Thanks
leicapixie
Check batteries first.
Use new ones and see contacts are clean.
If problem persists, suggest service..
AS these SLR bodies are so inexpensive these days.
perhaps get another, with warranty.
rbfigueira
The batteries are just fine and the contacts are clean.
I have bought other camera (also pentax Me) but I am trying to fix this one!
Thanks
Thanks
ucit
This is a common ME problem. I have two of them that developed the same issue. It has something to do with dried out rubbers in the mechanics. I once found a link to a website which explains how to replace them but I seem to have lost it.
rbfigueira
First of all thanks for your reply.
Please, if you find the link ... post here. For the price, sending this camera for repairing is not a very good option ://
Thanks
Thanks
ucit
Not the link I originally found, but it will hopefully help you somewhat :
http://www.rangefinderforum.com/classics/forum/messages/2/22122.html?1313787961
I will post back if I find that one guide
ucit
FOUND IT!
required some digging through old backups, but I recovered the link!
http://mysteryonion.blogspot.nl/2011/08/that-is-two-me-super-cameras-now.html
this blog explains in detail the procedure of disassembling and fixing ME (supers).
