ChrisP
Grain Lover
The film counter on my MX won't reset. Any quick fixes for this?
titrisol
Bottom Feeder
It maybe a bit of dirt in the reset lever.
Open your camera and press on the reset button several times with a jeweler's screw driver
while holding the camera with the film chamber looking " down"
It may also be a spring in the counter that has gotten weak, that is an easy fix too but requires a bit more effort
Landshark
the reset is in the groove for the door, just below the advance lever.
titrisol
Bottom Feeder
It is quite common that light seal gunk will fall in this area; also if you refeshed the light seals you may have overlooked these spot (it happens to all of us once)
I have marked the location with the toothpicks, and also look in the film gate for a notch (circled) that will help you find the lever.
Use a toothpick or a small screwdriver to push on it a few time and see if the counter resets.
