Photo Mythbusters - Does R-D 1 RF patch move in the frame?
jlw
Rangefinder camera pedant
11:03 AM
Recently, on another thread, an R-D 1 user wrote:
I... don't like to use accessory viewfinders, instead using the focus patch as a guide. This actually works pretty well except for the fact that the patch moves in the frame. The M8 won't do that and should be a lot better guide.
Wait, I thought, I didn't think that the R-D 1 focus patch actually moves as you focus. It may look as if it's moving, because the framelines do move, and a focus patch that stayed stationary relative to the moving framelines might look as if it was moving instead. So, what's really happening in there?
I know this has been controversial in previous threads. So, in the spirit of my favorite TV show, Mythbusters, I made up a "rig" to try to find out.
I set my R-D 1 on a table and blocked it up so it would stay solidly in place. On it I mounted my 28/1.9 C-V Ultron, since it has the widest distance range of any of my lenses (its close focus limit of 0.7m is actually closer than the camera rangefinder couples -- the RF coupling arm stops coupling at about 0.85m.)
Five feet behind the camera eyepiece, I mounted a Nikon D100 equipped with an 80-200mm lens. I aligned the Nikon carefully so it was exactly in line with the R-D 1's finder eyepiece. When I zoomed in the SLR's lens, I could see the R-D 1's rangefinder patch within the eyepiece. If the RF patch moved at all, I should be able to see it easily by comparing its position within the eyepiece frame.
The picture attached shows what I saw: the upper part is at infinity, the lower part at 0.7m. See any difference in the position of the RF patch? Nope, neither did I. (The shape of the patch changes slightly -- you can see a rounded edge on it at the close-focus limit, as the RF image shifts and reaches the edge of the round field lens. But it's clear that the overall position of the patch stays right smack dab in the center of the finder. Myth busted.
But that's not exactly what the poster quoted had said. He said the RF patch moves "in the frame." That IS true, in a relative sense -- if the patch stays still, while the framelines move, then the position of the patch within the framelines will change as you focus. So, while the patch doesn't actually move, its position relative to the framelines does vary -- which indeed would make it more difficult to use the RF patch as an auxiliary viewfinder. Myth confirmed.
Now, will the Leica M8 really be any different? Well, oddly enough, I don't have an M8 handy on which to perform the same test! But if we look at the designs of the two cameras' rangefinders, we can see differences that suggest how they'll behave.
The second picture attached is a diagram of a Leica M6 rangefinder, which I borrowed from Erwin Puts' website. (I assume the M8's RF optics will be similar to these.) Follow the red arrow that traces the rangefinder-image light path, and look at the frameline mask in this diagram. You can see that the rectangular aperture that forms the sharp-edged rangefinder patch appears to be part of the same plate that forms the framelines. This plate moves diagonally as you focus, to cause the framelines to compensate for parallax. If the RF mask is really part of the same plate, then the rangefinder-patch rectangle should move in step with the framelines, just as our quoted post infers.
For comparison, the fourth attachment shows a diagram of the R-D 1 rangefinder, which I scanned from my Japanese R-D 1 World book. I've marked the parts of this diagram which show the RF mask and the frameline mask. As you can see, in the R-D 1 these masks are separate pieces, in different locations. The frameline mask moves diagonally to compensate for parallax, but there's no mechanism for moving the RF mask.
This explains why the R-D 1's rangefinder spot doesn't move as you focus, while the framelines do move... while, conversely, an M Leica's rangefinder spot and framelines would move together.
Whether it's "better" for the RF mask and framelines to move together or not is debatable -- it's probably a matter of personal taste. Personally, I like for the RF patch to stay put, so I always know where to look for it; someone who wants to use the RF patch as a viewfinder reference would naturally prefer it to move like the framelines do.
Other than that, I hope this "investigation" puts the question of R-D 1 rangefinder patch behavior to rest once and for all!
LCT
As the mysterious RD1 user, I can confirm that you are 100% right about the RF patch staying fixed and the framelines moving. That was a pretty impressive and conclusive proof you went to the trouble of presenting. I also hope your right about the M8's RF patch moving with the parallex correction. For those that don't like accessory finders for tele work, the Leica solution is much to be preferred.
Rex
I agree, with the 50mm at close focus, the rangefinder patch is clearly off to one corner and if there had been framelines for the 90mm lens, the patch would be at the limit of the framelines, maybe even outside them. It's much better to have the rangefinder patch stay in the centre of the parallax adjusted frame.
How the viewfinder/rangefinder will be in the M8 is a big unanswered question. The least expensive route is simply to use the M7 finder and change the masks and the viewfinder magnification to suit 28-90mm lenses; we expect the 135 will not be usable, so that would be 28/90, 35, 50/75. My hope is that they've gone further than this and provided support for the 21mm as well.
A moving RF patch has disadvantages if you're used to using the edge of the patch for focusing.
Philipp
you've read the theory - here's the proof!
In the single-frame pictures, it looks like it's the RF patch that moves, but that was due to me trying to get the framelines in with my little P&S! The overlay proves that the RF patch stays still relative to the outside scene.
Nachkebia said:
Well, if frame lines move how come my ZI is way off at 35mm? on far subjects too...
The Z-I may have a different RF mechanism than either the R-D 1/Bessa or the Leica Ms. So far I have not been able to find any diagrams or information about its inner workings.
So, the results of our experiments won't be applicable to your camera. Sorry... more research is needed here!
