Pinhole for X Pro 1?
rybolt
10:37 PM
I don't want to bore anyone but here's how this started. I have 6 lenses for the pair of Pro 1 cameras and got tired of them rattling around in the Domke bag slots. So I bought ten rear caps on the auction website and did this:
Old Nikon School trick that still works.
With the ten rear caps I also got ten body caps. I'm thinking of drilling them out and trying to make a pinhole lens. For a 35mm frame I seem to need a .25mm hole. For an APS-C frame I would think that the hole should be about .18mm. Or am I going the wrong direction? I'll probably drill a couple of these and see how it works. I know that the plastic isn't going to drill round enough but if I can make it work I might have a brass insert put onto one of them and a more precise hole cut.
Or should I just forget the whole thing and go take pictures with lenses that have glass in them?:)
I am 99% sure you will need to use a metal insert.
Also, I am 75% sure that drilling won't work too well as it leaves burrs around the hole edges. If you can somehow de-burr the edges (that's a small hole !) . . . ?
You can buy a body-cap pinhole for $20 or so.
EDIT: you should move this to the "pinhole" subforum !
I have Skink pinholes in Leica M-mount, FourThirds SLR and Micro-FourThirds mounts. They aren't cheap ... $50-90 ... but provide way more options for doing pinhole photography, and are very nicely made.
http://skinkpinhole.com/wp/
I just keep the stack of excess body caps in a bag in my equipment cabinet. ;-)
G
G
This is true.
My experiments with pinhole images have not been good, but I am using a cheap lenscap type pinhole from Ebay. I'm getting the same old same old "blah" pictures (and of course I blame my equipment :D).
I have a Skink set on order - "hope springs eternal . . . ".
This is true.
I've put some of my Skinky pinholery and zone plattery here for your amusement:
http://www.flickr.com/photos/gdgphoto/sets/72157627775078690/
Whether it's any good is, of course, a toss up based on personal aesthetic. I have more, just not posted ... like a set of pinhole portraits I'm working on. It takes a while to learn how to use pinhole and zone plate effectively.
G
G
Yes, Godfrey, I have viewed your work before (in fact it was a big factor in me trying pinhole) and I just love your pictures.
It's a totally different mindset to pre-visualize a good pinhole composition, and I haven't found that groove. The one common element seems to be a very rock solid composition of areas in the frame (maybe strong thick lines too).
And I can imagine using the Skink gear effectively takes much practice and tons of evaluation.
Always something new to learn.
I've successfully made pretty decent pinholes myself using soda cans as the material and a tiny drill bit or pin tip. But I found the quality to be much better from the laser drilled versions you can find online.
If you are going to convert a few of those body caps to pinholes, you might consider purchasing a few sizes of pre-made pinholes and gluing them to the caps for an assortment of sizing options to try.
Have fun either way, as that is what really counts. :D
I bought an m39 (LTM) pinhole in ePay
Only tested it in my E-P2 since the m39 adapter for the Fuji didn't arrived yet.
I already have the Holga pinhole and the PinWide for micro4/3 and this m39 is probably the best of them (crisper) and cheap as the Holga one. It's FL it's around 50mm
If you want to find it just look for a m39 pinhole made in a LTM body cap using an etched copper film in the center of the cap
I bought some lens caps for my Fuji and did the same thing when I first bought my xp1.. I now have two extra body caps..collecting dust. Nice idea.. I think I will give it a play :)
Gary
Forum newbie here, so Hello All, and my apologies for coming to this a bit late.
I had been dabbling with pinhole photography on my Canon slr and dslr, so it seemed only natural to have a go when my X-E1 arrived ;). I bought one of the brass shim pinholes off an auction site, I think I worked out it needed to be 0.18mm dia. I fitted the shim to a drilled out body cap, and from the 'test' shots, all seems to be OK, I just need to find a bit of time to head out and take some serious, properly composed images!
Links to a couple of the 'test' shots on Flickr
http://www.flickr.com/photos/nigell/8754529485/in/set-72157633353310993/
http://www.flickr.com/photos/nigell/8755653288/in/set-72157633353310993/
Nigel
I received my LTM adapter and can happily confirm that the pinhole (see above) works very very well with the X-E1.
I'll post some examples when possible, did some landscape tests.
I also attached a dark yellow filter in front of it for some.
It's FL is 45-50mm equivalent (so around 35mm on a real LTM camera, wow)
Happyness!
