Planar 50 self service?
podcat
12:03 PM
Hi, my planar gets pretty stiff in colder weather when its been sitting in the bag. Its fine at normal room temperature etc. As winter approaches this is increasingly annoying. I assume its been lubricated incorrectly and I'v only had it since summer where I never noticed it.
Has anyone re-lubricated their planar? How tricky is it taking it apart for this, I can't seem to find any technical information through google. I could try and find someone who services manual rangefinder lenses but if it isnt a tricky operation I would rather do it myself
If you bought it new, send it in for warranty service. If not, pay a tech to fix it. Taking a rangefinder lens apart and getting it back together where the focus remains accurate is near impossible without the correct equipment used by repairmen. I know, I ruined a lens that way once.
Yeah you are probably right. I'v only taken apart and cleaned SLR lenses and I imagine this is trickier. The lens is 2nd hand so no warranty or similar and I'v been happy with it all summer - the stiffness only shows up when I'v been out in the cold autumn evenings with it in my bag.
I'll see if i can find a repair guy in Stockholm. Tips welcome!
the planar is a pretty basic lens so i don't see why it would be trickier to relube than an SLR lens. i'd certainly give it a try before sending it off.
well, I'd bet a rangefinder lens is much more sensitive because of the mechanical coupling. It doesn't matter as much if an SLR lens has its focus shifted a bit because you focus by looking through it.
If you're in Europe, send it to Zeiss/Germany or contact them with your problem. After all I've read here, their customer service is excellent. The cost might be much more reasonable than you expect.
Appreciate you've met a guy, but I'll second Zeiss' service recommendation. Excellent and not as expensive as you might expect.
Yes, the cost with my guy in town is under $50 for a re-lube on a lens...
May I make a suggestion the next time you go out in the cold with extra lenses?
Put the lenses in a wool or heavy cotton sock, then in the bag it goes..
I seldom bring more than once lens, I find that I spend too much time switching between them rather than taking pictures ;)
Got my planar back from Jonas the other day and the problem seems fixed now, no issue yesterday when I was out in the cold. He said the old grease was of a bad type and had also leaked around quite a bit so he cleaned it and put on new grease.
Also got to drool over some of the cameras he had in for repair, including a real user of an M4 with beautiful brassing all over and the most banged up lens hood I'v seen for a 35.
