Plustek OpticFilm 120
  • Superb, I have had no issues with it
    Votes: 7 20.6%
  • Very Good, I had some issues but they have been sorted out
    Votes: 12 35.3%
  • Good, there are still some minor issues with it but they don't bother me
    Votes: 5 14.7%
  • Fair, there are some issues but I can get round them somehow
    Votes: 2 5.9%
  • Poor, there are important issues with this scanner that cannot be resolved
    Votes: 8 23.5%
  • Total voters
    34
lawrence
2:30 AM
My sixty-fifth birthday is coming up in October and I've been toying with the idea of treating myself to one of these, however I have read some negative comments about this scanner. I'd really appreciate it if current or past owners could give me an idea of any issues with the scanner before I make a decision.
Lawrence, first, happy birthday. I have been an early adopter of the Plustek 120 and continue to use it with high regard. But like many things, it takes some time to learn the machine and its capabilities. And while I do find it works very well for me, I am sure you will hear from others who do not like it.
I have had no issues with the machine itself, the scanner has worked without any mechanical issues for the past 3 years. The biggest issue for me was the earlier versions of the SilverFast software and an alignment of the scanned frames. The folks at Plustek worked with me and sent me software and updated drivers, which has since been incorporated with the newest version of Silverfast, the packaged software. The issue was resolved in that you now have the ability to "move" the rescanned framed images, to get precisely what you want, the full frame. Maybe one in 50 scans I need to reload the negs in the holder and tweak it a bit, but really no longer an issue.
I used VueScan as well, bit did not see any real advantage for my work flow. However I do use this for another Epson scanner.
I routinely make 17x22 inch enlargements with the scans (from mainly 120 negative film) and the images are superb.
I like the scanner, and for me, it has done very well. I continue to learn new things with it, and I have no complaints.
I was also an early adopter. I've no issues with the scanner itself but I find I have to move the negatives around in the holders to find the right position to scan the whole frame. It's not really too much of a problem. Another issue is I need to keep my finger in the slot of the machine holding the door up or the door will prevent the movement of the holder back out of the scanner. This is only an issue when scanning frame 2 of 6x6 or 6x7 (I don't use any other format other than 35mm). I use Vuescan. Otherwise I'm perfectly content with the scanner.
Pete
Scan-160801-0006-Edit by Mr Chombee, on Flickr
Same here, had one of the first ones in Canada.
Only issue was the early versions of the software which have been updated.
I'm mostly scanning 120, Linhof 612, but also 6X6 and 35mm.
cheers/k.
Hello
I can certainly recommend the Plustek OF120. I had some minor software problems with Silverfast but they are mostly resolved.
Now I almost exclusively use VueScan for OF120. Thats because I get better colors with Whitebalance or Autolevels. Besides that I can tweak underexposed or overexposed slides better with VueScan and it scans much faster than Silverfast, so I happily use Light IR cleaning.
I would only use Silverfast for black and white fillm (Software cleaning of BW film).
The alignment of the frames for 6x6 scanning is a definite problem to me.
I use Vuescan. I gave up ever getting 3 squares. I just take one square (Frame 1) then two cropped frames. If I try to scan just Frame 2, the scan crashes. The holders don't even vaguely fit most strips of three 6x6.
The scans themselves seem good. 35mm is also good.
I only had a limited amount of patience and time for overcoming the 6x6 issue so maybe others had more success.
I'm quite happy with the scans, but as coogee says, scanning more than one 6x6 frame in a holder is only possible with some hacking: I had to cut the middle 6x6 holder frame to allow resizing and freely moving all 3 frames on the rails. Then I have to cut my strips into single frames and position them in the now freely movable frames individually where the scanner expects them. Then I can scan all 3. Still much better than doing them one by one, but for the price of the scanner and how well it works with 35mm strips, I find this to be rather disappointing. But it's still the best multi-format scanner on the market.
-N.
It's a fantastic scanner. I don't own mine any more, since I stopped doing 120 completely, and I don't have a lot of time for film (or photography in general any more), so I sold mine. But it's the best 120mm and 35mm scanner for home use that I've ever tried. Expensive though.
Many thanks for the feedback. Still considering this because, as you say, it's not cheap...
I bought one and it had really bad banding on 120 scans. I did some looking and this is a big issue with multiple users reporting this problem. There is a big flickr thread about it. No resolution came from Plustek. Also the lack of AF or even MF is a stupid move for a scanner of this price. My cheap (and EXCELLENT) Pacific Image Primefilm XA has auto and manual focus and it cost me about $300.00. The Pacific Image is a rebranded "Reflecta". Not sure why the name change, but Reflecta also makes a 120 scanner. Given that my experience with my XA has been so good I would definitely consider it. It's cheaper to boot.
Lawrence,
Thanks for this thread. I'm looking into this as well.
BTW, B&H have a $300 discount currently on the scanner.
I haven't done much medium format with it recently, only 35mm. I never use Silverfast - no documentation (to speak of) and utterly incomprehensible interface. I use Vuescan, with which I am very pleased.
The real problem with this scanner is the misplacement of frames - for some reason it just gets off by a few millimetres and you have to remove the tray and reload. Either that, or be prepared to lose one side or other of your frame. So painful, not terminal, but painful. I really do not know why they could not have prevented (or solved) this issue. it's a lot of money for something which doesn't really work as it should.
Having said all of which, it probably offers the best scanning around at the moment, and will deliver better quality than a flatbed if you are prepared to live with its quirks.
rjstep3
rjstep3
They solved that (partly) by giving to you an offset option underneath every frame in the Overview.
Of course you still can have severe uneven spacing problems whereby a frame goes underneath the crossbar between holder frames. In that case you have to eject the holder and reposition the film.
I'm looking to buy this scanner and Mamiya 7, wondering what are the real scan times per 1 roll of 120 film (10 photos 6x7) on 2017 Windows 10 PC (Xeon e5-2620 v4 and 128Gb ram).
The filmscanner.info review has it at 10600 ppi resolution between 33 and 60 hours.
One of the sites that reviews and sells scanners used to carry this and noted that they stopped because of quality control issues. I bought and restored a Nikon LS8000 instead. Very very very pleased. Note that I have a Plustek 8200 and it is a royal PIA by comparison.
The OpticFim 120 is so far out of my price range that any issues with it, technical or otherwise, are beyond my care. I do know two photographers who have bought it. One had technical issues, now resolved. The other produced excellent scans with his from Day 1.
This may brand me as a Luddite, but I blew my budget in 2009 and bought a (then new) Plustek 7600i which continues to serve me well after 10,000+ scans - but with several tens of thousands more negatives and slides yet to be done, I will surely need another complete lifetime to finish the job.
Apart from being infuriatingly slow to work with, the 7600i does all I expect of a scanner. To me the Software (Silverfast) is the PITA.
