Prescysol / Prescysol EF
Austerby
3:33 AM
Fircombe
Anyone else use this? I've tried both formulations, not sure if I can see the difference between them but I love being able to develop any film together as I'm quite a one for mixing films up. It's a staining pyrocat type developer and I've been using the semi-stand time of 10m30s with a whole range of film types - from HP5+, through Acros 100, PanF+, Neopan 400, Tri-X, CHS50 and Tmax400 - (120, 35mm and 4x5) - all with really good results.
It handles contrasty and non-contrasty scenes well, the film latitude is wide, and you get lovely, lovely tones with it.
Any other users out there in RFF land?
e.g. 1
Normandy orchard by Vidwatts, on Flickr
e.g. 2
Cabin roof & pushpit by Vidwatts, on Flickr
It's a great developer. I used to use it a lot and never had a problem with it with a variety of films (worked well with Delta and Acros as I recall). The only awkward part was getting the alkaline stop, but I think just using water is OK.
This is my go to developer these days. Easy to mix, foolproof & reliable results.
Added to that, Peter is a top bloke, and is always helpful for advice.
Regards Jonathan
It is a great developer (Prescysol EF), as long as you don't need to enhance speed - in fact it reduces the speed of most films, and as long as you don't want to see dark skies - for whatever reason they always turn out white, even when using a red filter.
MF20091405 by mfogiel, on Flickr
