Process Efke 400 and Tri-X 400 in same tank?
WDPictures
11:54 AM
If I'm using the same development times per film speed there shouldn't be a problem souping these two films by different mfr's in one tank, correct?
Correct. (That is, if the speeds you shoot these films both require the same amount of time in your soup for proper development, you can run them together with no problems.)
