Mr_Flibble
In Tabulas Argenteas Refero
Early December I bought an old projector lens at a flea market in Amsterdam.
Most likely a projector lens rebranded and sold by the Ed. Liesegang company in Düsseldorf around 1900.
A little research leads me to believe it's a petzval lens. Great!
Unfortunately the rear crown element is missing. Bugger!
No way to focus it on a ground glass.
A little more research told me the front two elements alone form a doublet lens. Which...makes this lens a not completely useless acquisition.
So I removed the rear lens and tested the doublet with the ground glass on my Speed Graphic and a dark cloth drapped over the whole issue.
Turns out that works quite well.
A fellow Dutch photographer sent me an unused Speed Graphic lensboard and a few minutes with the dremel allowed me to mount the lens on the camera.
I can focus from about 5" to infinity with it.
Haven't figured out the exact focal distance and f/stop value of the lens yet.
Focused at infinity, the distance from the doublet to the ground glass gives me about 250mm.
The diameter of the doublet is about 60mm
So the most basic calculation would give me 250 / 60 = f/4.166666.
Time to shoot some film with it.
As an alternative I bought a couple of bi-convex lenses with the right diameter from Surplusshed.com . Not sure if they're anywhere near the correct focal length, but I'm hoping it can serve as a replacement for the missing element. Hopefully giving me a complete Petzval formula again.
Why are we doing this again?!
oh yes.... FOR SCIENCE! 😀
