Canon LTM QL17 'better battery'
Buttershug
8:38 AM
for those of you still running a 1.5v SiO cell in your GIII QL17 - thought I'd just share an experience; I recently bought and put in one of the 1.35v 'Wein cells' from "Vintage Batteries"; (http://www.vintagebatteries.com/battery.html) and have been running it for about two weeks now.
The camera operates 100% better in my opinion - the meter is more responsive and a great deal more accurate (yeah, I know - 'duhhh it's supposed to run on 1.35v!') - I have only ever run a 1.5v cell in it so all my previous experience with the meter in the cam is based on how it operates on the SiO batteries.
The pics from my last roll are just SO much better on the Auto setting than I've had before. I guess it's just operating as nature intended.
Apparently these batts last a good deal longer than normal zinc/air's - up to a year under normal use (whatever that is) - but we'll wait and see on that one. BTW, the service was great from the VB guy - and I couldn't be happier with how the cam is running now.
This is probably old news to most of you but I thought I'd share a 'user experience' for those who haven't had a chance to try these zinc/air's in their QL's yet.
Best,
David.
I'v heard that if you are not using your Wein battery, you can take it out and reapply the sticky to prevent it from degrading further.
I bought up a dozen or so of theMerc's before they disppeared My cameras have always been feed the proper voltage. Normally when I have a camera tuned up if the circuitry in the camera will allow it I have my guy install a voltage regulator to allow the use of a Silver Oxide battery.
yeah, I guess this is what they refer to as 'recalibrating the meter' to work with the 1.5v cells. Just what is involved in doing this? I've heard of soldering a diode in series with the battery to step down the voltage - but electronics is not my strong suite so i could be wrong here. For those of you who have done it - or had it done to your canonet - just what's involved? Is it something the 'tinkerer' can acheive or is it a service-guy-only gig?
thanks,
David.
Buttershug said:
thanks,
David.
The diode fix will work on the Canonet but I find it much easier to lift the top and adjust the small "pot" behind the film movement flag. I than use normal SR44 batteries with an aluminium collar as a good friend got a batch turned up. Failing this, Get hold of a good light meter, or trustworthy camera and adjust the ASA dial until you get the same reading on both. Then in future always offset the ASA by the same amount (sorry, should I be saying ISO these days?). finally remember to use silver cells rather than alkaline ones. The silver ones have a higher voltage but a "flat" discharge curve. The alkalines have a slightly lower voltage but it decreases as the cell is used.
Regards
Kim
I have found that tuning the meter does not always fix the problem - some cameras have a linearity problem - i.e. the meter is OK at one end of the EV range, but out at the other end, or somewhere in between.
The diode fix depends on the camera and how much space ther is inside. I have successfully done this on Konica S2 ans S3, but just could not find space inside a Rollei 35S.
My preferred solution is to make my own equivalent of the CR-9 battery adapter - this allows me to use the SR44 and keeps the camera prisine.
You folks have heard about hollowing out the alkaline shell and using a hearing aid battery (less than a dollar each), haven't you? I activated a hearing aid battery at the end of October, and it is still going strong today. Please let me know if you don't understand what I'm talking about. In my opinion, this is a very nice and economical alternative.
Jon
Which battery did you buy? I picked up a Wein Air Cell which was a replacement for a PX625 Mercury, but it doesn't appear to be the right size. It's much smaller than the Varta 1.5V I'm using right now.
EDIT: Nevermind!!! I forgot to put on the little metal ring that makes it the correct size. D'oh!! :bang:
Help! This is Canonet & I are having "issues" and they're about to culminate in a parting of ways if I don't get this figured out quick!!!
I've got the metal ring in place, but now the battery check light won't come on and neither will the meter. I've tried moving the ring around and moving the battery itself around in the compartment, but nothing works. If I put the Varta back in, though everything is fine. What gives? Is my Wein dead?
*sigh*
I think the Wein is dead. I seem to be cursed with dead batteries this year.
The Varta I had when I first bought this camera was getting old, so I went to get a replacement at the local camera store. They sold me a Duracell 625.
It was dead.
I returned it, got a new one, and put it in the Canonet.
It was dead, too.
Returned it and got them to test it this time. Definintely dead! (20% charge.) Got a Varta this time.
Went on vacation with my wife to the mountains of Virginia. Took my Minolta A5 RF and my Nikon FE SLR. Saw a nice sunset over the lake and decided it was a good opportunity to break in my new Sigma 24-70 2.8 lens I'd bought with Christmas money, so I brought out the FE.
Battery was dead. (Thank God the A5 doesn't have a meter and, therefore, doesn't need batteries!)
Bought a replacement at the local camera store (a Kodak 3V) and went for Easter dinner with my relatives. Brought out the FE to get some shots of the egg toss after my wife & I were eliminated, but the meter needle didn't move.
Battery was dead. Replaced it with two Varta 1.5V.
Two of our friends had a courthouse wedding yesterday and my wife & I were the witnesses. They handed me their digtal camera to take some shots during the ceremony. I took the first one and the camera suddenly shuts down.
Batteries were dead.
I think I'm going to invest in a selenium light meter and stick to using the A5 from now on. :rolleyes:
Captain Slack, Your tough on batteries...Does your car start every morning?
I avoid the Duracell batteries. Of all the photo gear I have gotten over the years Duracells have been the ones that leak acid the most and mess up old gear...When they started making the lithium cells for EOS cameras sometimes you could only get thru 3 rolls of film before that $12 battery died...The Canonets I have had there was enough tension in the battery holder that one of the small hearing aid batteries fit without any kind of shim to hold it in place.
Just set the film speed to 2/3 of a stop slower. I calibrated it against my Nikon FE at iso 260 for 400 speed film. Seems to be linear from EV 6 to 16 - didn't check outside that range, but I suspect it would be the same.
I just got done doing the diode trick on a Weston Ranger 9 meter. You use an NTE583 Schottky barrier diode, soldered in series with the wire from the battery compartment. These diodes can be ordered online from Arcade Electronics for about $6 apiece. You insert the diode into the wire that comes from the + terminal of the battery compartment, with its anode end toward the battery and its cathode end (marked with a line on the diode) toward the camera circuitry.
If you can get access to the battery compartment, it's within the scope of a tinkerer -- but you need to be good at fine electronics soldering, because the diode is VERY small (about 1/3 the length of a grain of rice) and it's also sensitive to heat, so it can be blown out of you apply too much heat when soldering.
In principle the diode is supposed to work better than just tweaking the trim resistor or splicing in a plain resistance. A resistor will reduce voltage, all right, but the amount of voltage drop varies according to the current draw of the circuit. And because a CdS cell measures light by varying its own resistance, the current draw of the circuit is changing all the time as the light levels change. That means the meter's response to light will no longer be linear -- you can pick a resistance value that will make it fairly accurate over partof its range, but you can't get it to be accurate over its full range.
(Sophisticated meter circuits have several trim resistors to adjust their linearity, and a good repair shop with a calibrated light source can tweak all these to get a fairly good full-range correction, but it's tough to do without the special equipment.)
Anyway, the reason the diode is supposed to work better is that a Schottky diode is a "majority carrier" -- it's a conductor and a semiconductor sandwiched together in such a way that electrons can flow in either direction, but are more likely to flow in one direction than the other (quantum mechanics at work!) That's how it performs a diode's basic job of being a 'one-way valve' for electricity.
A bonus by-product of this is that the forward voltage drops as it goes through the diode (because of the statistical probability that some of the electrons will want to flow the "wrong" way) and because this is a statistical process, the amount of voltage drop stays fairly constant over a wider range of current draw: no matter how many electrons try to get through the gate, about X% of them will always get "turned back."
The voltage drop of this particular diode just happens to be about perfect for dropping the nominal 1.55v of a silver-oxide cell down to the 1.35v of the original mercury cell, at the kinds of current draws typical of a meter circuit. So, if your solder-fu is strong enough, adding this diode to the meter circuit is almost a 'bolt-on' way to convert it from mercury to silver oxide power. (If your meter circuit uses two batteries, add two diodes in series.)
I don't remember enough from my QL17-owning days to recall how easy it is to reach the wires coming from the battery compartment -- but IF you can reach them and if you're confident of your soldering ability, this might be worth a try.
CaptianSlack,
Get the Lithium 3volt battery for your FE2, it'll last a LOOOONG Time.
Also obtain an inexpensive volt/ohm meter, less than $10 at Radio Shack. Then you can easily test your own batteries.
Like Mark, I bought a bunch of the real PX625's before they ran out. They will last me till I'm pushing up daisies ~ ; - )
nwcanonman said:
CaptianSlack,
Not a bad idea on the voltmeter, there! I wouldn't have thought of that on my own. Thanks!
My sister lives in Germany and I asked her to keep an eye out for some real Mercury cell's. I doubt she'll find any since I believe the Germans are a lot more eco-conscious than we are in the US, but it's worth a shot.
Hi All,
Another px625 replacement idea comes from Frans in the Netherlands. No relation to the guy at all, but I read his article on the matter at http://olympus.dementia.org/Hardware/PDFs/batt-adapt-US.pdf and then I emailed him and ordered to ready-made adapters. And they seem to work great in the Olympus SP and the Pen F clip-on meter, and much better price than the CrisCam ones. His contact info is on the pdf file there. Hope that helps someone!
cheers
doug
Or you might want to look for a real batter tester instead -- think you can still get those at RS also. A straight voltage reading from a VOM won't give you a valid test unless you simulate the load of the meter circuit. A dodgy cell may put out nearly its nominal voltage under no load, but then drop enough to produce inaccurate readings once a load is applied. A battery tester will include a simulated load appropriate for each type of cell.
Jon
I agree. 1.4 v is pretty close to 1.35. And you can use a rubber o ring to expand their size. Or stuff some aluminum foil to get the right thickness.
Took the "dead" Wein back and got a replacement. Same result. :bang:
Apparently my Canonet doesn't like the air-cell, since I doubt I've gotten two dead batteries in a row (but with my previous luck this year, I can't count that out!). If this camera, at some point before I got ahold of it, had been modified to accept the 1.5V batteries, would the meter still work with a 1.35V battery?
