QL19: What kind of battery?
MazG
5:00 PM
My QL19 battery compartment is a bit different than those I've seen posted here. I am wondering what kind of battery I need to get to use the camera's meter.
Here are some pics:
Camera top: http://www.hamersleyfamily.com/photos/ql19/3.jpg
Camera front: http://www.hamersleyfamily.com/photos/ql19/2.jpg
Battery compartment lid: http://www.hamersleyfamily.com/photos/ql19/1.jpg
Camera bottom (batt open): http://www.hamersleyfamily.com/photos/ql19/4.jpg
Camera bottom (batt closed): http://www.hamersleyfamily.com/photos/ql19/5.jpg
I'm about ready to ebay this camera and try to pick up another version, as I've had it 6 months and have just about given up finding the right battery.You are my last hope 🙂
TIA, Maz
Full details here. http://www.smallbattery.company.org.uk/index.htm?http://www.smallbattery.company.org.uk/sbc_lr50.htm
You can can battery adapters or calibrtae the meter for the increased voltage. The latter is not the best solution as I have yet to come across a silver version of the battery and the discharge curve for alkalines is not very flat. It's probably OK for print film but I would use a handheld for Slide.
Kim
ICU said:
I am not positive, but I think the original battery was a 1.3v mercury RM1 battery. I don't know what the modern substitue is. Good luck.
Mary
I use the Kanto/ C.R.I.S adapter w/ Silver Oxide batteries and have NO problems. However, Kanto (Japan) has been more friendly to deal w/ than C.R.I.S (USA).
Suggest search B&H for mercury battery or wein cell. Not sure if your size is covered, but there's a good chance.
The MR1 is an odd size battery. I don't think there is a wein cell alternative. You could get away with using a zinc/air of the right diameter and using packing. Because of the size of the battery, making an adapter should be much easier than for the more normal size cells. I haven't tried that route but only because John Neal made one for me.
Kim
It looks like you have the first version QL - this needs a Mercury PX1a cell that is no longer available.
I can make you an adapter to use the widely available SR44 cell (same as the Cris one, but much cheaper). Send me a PM if you are interested.
