Question about a hood for a Hasselblad lens.
Keith
8:01 AM
Will this cheapie hood be OK on my recently aquired Hasselblad lens ... it's a C T* 80mm F2.8 Planar?
eBay link
It's the lens that has the aperture and shutter dials linked by default and you have to lift a tab to separate them and make independant adjustment! I'm pretty sure that's just the C lens but with the T* designation indicating multi coated.
I just wanted to be sure before buying the hood!
That hood should fit your lens. The older C lenses and the newer CF models look quite different from each other. With a little bit of googleing I'm sure you'll find pics of both. The CF Planar 80 is with B60 bayonet and the older C model with B50.
edit: your Planar should look like this but it's most likely black http://static.photo.net/attachments/bboard/00L/00LU2L-36948584.JPG
