R
ruben
Guest
I am investigating now what use can I have for the meter at the Kiev 4. And here I have a very important question, at least for me.
You may have noticed that if you select for example the film sensibility of 250 roct (something slightly over ISO 200), then the meter speed dial will stop at a point showing 1/1250 at f1.5. This means that the other equivalent combinations at the scales, for the same film sensibility, will be something like 1/50 at f4, or 1/25 at f/5.6.
But I "need" the meter to read, with the same film sensibility, lower light levels like 1/25 at f/2, and the speed dial refuses to move.
So my question is if this is a design shortcomming of the dials, or the real limit of sensibility the metering cell was designed for. I cannot check it since my cell is not new (but a new one is under way).
Ruben
Ruben
