Question about Voigtlander 40mm Viewfinder
Adam14
8:29 AM
Because I wear glasses,I have trouble seeing the entire 40mm framelines on my Bessa R3A with the Nokton 40mm f/1.4. Would the Voigtlander 40mm Brightline Viewfinder solve this problem? Anyone have any experience with this device?
Thank you
Short answer: Yes. It's a very bright finder and the framelines are easy to see. I use it on my Bessa T w/ a 40: works great!
Yes, usability for eyeglass wearers is very good. Also very bright image. Be aware that the 40mm VC finder is optimised for Leica M bodies in the sense that the finder is a tiny bit offset with regards to the hotshoe mount. This in order to reduce lateral parallax error on Leica M bodies, as the lens axis and the hotshoe are not laterally aligned on M bodies.
