Question for G1 owners...
reala_fan
12:26 PM
All ye G1 owners...have question:
It's my understanding that the G1 employs some sort of 'software correction' to the images taken.
So, if I use Olympus lenses on the G1, does it know to apply the 'corrections' to the Olympus images?
Interested in using the OLY 25mm pancake and OLY 14-42 'new' kit lens, and OLY
11-22mm on a G1 body.
Will they focus okay? Will they be 'software corrected' okay?
Focus will be OK (unless you updated to 1.4 and have same issue as me). And it will be corrected properly. Just there chromatic aberations will be there.. cause Olympus lens doens´t fix that. Panasonic lens correct even CA.
All corrections that should be made are on chip in lens. Every m4/3 body can read and use that info.
Oly 11-22 and 25mm is I think normal 4/3 right? If yes, it will work via adapter just ok..
Everything should work as you want. :)
