question for the optics / lens gurus
Papercut
9:37 PM
I'm considering getting a reasonably priced portrait lens (75 - 90mm) for my Zeiss Ikon ZM. Two of the candidates on my short list are the 90mm Elmar (LTM) and the 90mm Elmar-C and I'm just wondering if there is any (real, noticeable) optical differences in these two lenses?
With the M-mount adapter for the thread mount lens the prices are within $50-75 of each other, so price isn't really an issue. I'm just interested in optical differences.
While the optical formula is probably identical (one never knows about what undocumented tweaks were done) you can expect differences in coating and mechanics. The Elmar-C has a slanted RF cam. And I am guessing just like for the 40/2, sometimes during the Elmar-C production multi-coating was introduced.
I were you, I would try to get a 90/4 Rokkor, different (better) RF cam, and definitely multi-coated.
Best,
Roland.
In terms of the look of these lenses, I don't have anything from a more modern Elmar or Rokkor, but the pictures below were taken w/ a clean, uncoated Elmar 90/4 black barrel from the 1930s:
Steve,
Thanks for posting those! Really sharp lens and nice OOF (2nd shot). The colors are gorgeous too! Being uncoated, I'd guess it's rather flare-sensitive?
-- kevin
Kevin -- I think it probably is, but I used an improvised hood consisting of a couple of step-up rings screwed together, so I didn't have a problem w/ flare. It's the way the lens renders colors that I find most attractive, but I had to return the lens to its owner and wound up getting the Canon 100/3.5 as my long lens.
I've heard of (and seen) some very nice results from the Canon 100/3.5, but the longest framelines on my ZI is 85mm, so I'm hesitant to go longer than 90mm as I suspect that framing/focusing would be tough...
